DIYnot
Local | Network
   DIYnot > Forums
Local | Network
IDEAL ISAR- NO CENTRAL HEATING
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
top banana
from United Kingdom
PostPosted: Mon Aug 20, 2007 8:33 pm Reply with quote
hello all,well i guess its that time of year when heating is switched on and problems occur!
have an ideal isar that is fine on hot water but doesn't supply heating.
i have overiden the radio signal from the thermostat but when the boiler has a 'c'on the readout the burner light flashes slowly but doesn't ignite.
any help please.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Mon Aug 20, 2007 9:38 pm Reply with quote
Bet you its the diverter valve
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5479 times
PostPosted: Mon Aug 20, 2007 10:11 pm Reply with quote
Indeed. can't remember what the rest position of the diverter is... but...
Back to top
 Alert Moderators
hav it
from United Kingdom
Thanked: 6 times
PostPosted: Mon Aug 20, 2007 10:17 pm Reply with quote
dont they have that grey actuator box, that goes on at a funny angle, then twist and locks on..
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5479 times
PostPosted: Mon Aug 20, 2007 10:21 pm Reply with quote
No, that as the later Honeywell. The earlier ones had a Cp diverter valve, which worked the same way but has a diferent manifold and actuator.
Easy enough to change as long as adequate space and proper servicing valves where fittted.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 803 times
PostPosted: Tue Aug 21, 2007 8:40 am Reply with quote
My money would be on the pcb, as boiler is getting signal for heat as in 'c' but is not firing. If it was firing but no heat then I would go for DV. PCB is notorious unreliable on these.
edit, maybe the thermistor/ntc for the ch is knackered. Worth checking first.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3564 times
PostPosted: Tue Aug 21, 2007 9:31 am Reply with quote
Since most of the internal operation is the same on DHW and Ch then its more likely to be the diverter valve.
With the boiler cold select CH and see if it fires up for 10-20 seconde to heat up the inside of the boiler.
The head can usually be taken off the diverter and the operating pin vigourously pushed up and down like external cardiac resusitation. That will often free it up for a few weeks!
Tony
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 803 times
PostPosted: Tue Aug 21, 2007 9:35 am Reply with quote
Yes but if the burner light is flashing slowly, then the boiler is thinking it is up to temp and just in circulating mode. OP says that it is going no further, fast flashing or lighting.
Another simple though OP, have you turned off mains for 30 secs at switched fuse outlet?
Back to top
 Alert Moderators
top banana
from United Kingdom
PostPosted: Thu Sep 06, 2007 8:28 pm Reply with quote
thank you very much for replies, i've just got back from summer hols and i'll keep you posted on resultsof your replies. thanks again.
Back to top
 Alert Moderators
the.ideal.man
from United Kingdom
Thanked: 1 time
PostPosted: Fri Sep 14, 2007 10:49 pm Reply with quote
we dont make that valve anymore, if you have seen any of the boilers this year you will know all copme with the grey head!!
Back to top
 Alert Moderators
top banana
from United Kingdom
PostPosted: Wed Oct 10, 2007 5:53 pm Reply with quote
well,had to get the sparkys in as nothing wrong with boiler but apparently problems with thermostat etc.
if i get a better low down i'll post it!
thanks for all your replies
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Isar ideal he35 boiler central heating constantly running 3 980 Wed Sep 17, 2008 8:54 pm
Ideal Isar M30100 - Constant Central heating? 2 80 Sat Dec 14, 2013 9:42 am
Central heating always ON- IDEAL ISAR HE-24 4 60 Tue May 01, 2012 9:12 am
ideal isar 30he (i have dhw but no heating) 10 680 Wed Jan 14, 2009 8:14 pm
Ideal Isar HE30 not heating water sufficiently. 6 360 Sun Mar 06, 2011 1:57 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
