Jackie2001
Joined: 21 Aug 2007 Posts: 1 Location: Canada Thanked: 0 times
Posted: Tue Aug 21, 2007 4:08 am Post Subject: peeling paint |
I just primed my bathroom but the original paint which I believe was only one coat is now peeling underneath the primer. I have no idea what kind of paint was used before and what I should do now since I have primed the whole bathroom. PLEASE LET ME KNOW WHAT I NEED TO DO? Can I paint over what has peeled off? |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Tue Aug 21, 2007 7:00 am Post Subject: |
If you want to, you can tell us what kind of paint you applied, and how you cleaned and prepared the surface before applying it.
It will do no harm to tell us if the old surface is drywall (plasterboard) or plaster on brick.
Post some pics if you can.
Was the old paint matt or silk, and how old? |
Colin.w.jones
Joined: 09 Nov 2007 Posts: 1 Location: South Glamorgan, United Kingdom Thanked: 0 times
Posted: Fri Nov 09, 2007 12:09 pm Post Subject: |
I have the same type of problem after using a one coat paint from a well known diy super store. My walls are solid with a plaster finish. I stripped wall paper from the walls then cleaned with sugar soap. After applying the one coat emulsion, several months later it has started to peel off. Any help please as to how to fix.
Colin |
billyo
Joined: 20 Jul 2007 Posts: 1508 Location: Cumbria, United Kingdom Thanked: 0 times
