main and supplementary bonding
8 Feb 2005
Hi
Does anyone know the best way to fill out a minor works certificate for an upgrade of the main and supplementary bonding
most of the questions refer to the specific circuit and as the work doesn't relate to any circuit in particular do the just get filled in as N/a
How did you gain creditation for competant person sceme if you cannot fill in a minor works form!!
hmmm, so helpful, thanks,
also, you dont have to be in a scheme to fill out a form you just have to be a competent person
and to be deemed competant i think you'll find you must register with a competant body organisation.
ack351 said:
I think you'll find your wrong
I may be wrong, but was under the impression that most BCO's will accept certificates from non-registered competant installers, ours will anyway.
Part p only covers addition of a new circuit and also bathrooms and Kitchens(wet areas)
so repairs,replacement of say a rat chewed cable or addition of a spur or extra light fitting to an existing circuit are all minor works.
it should be tested with one end disconnected and method 2 long wandering lead and low resistance ohm meter max reading 0.05 ohm
