Joined: 14 Aug 2007 Posts: 10 Location: United Kingdom Thanked: 0 times
Posted: Wed Aug 22, 2007 12:48 pm Post Subject:
We have an accenta alarm,unit bleeps but doesn't set.?
hello its me again this time problem in my house alarm i tried setting the alarm but the alarm don't sets and beeps and only shows zone 5 and that is the kitchen i go in the kitchen and walk pass but the sencor is not showing a light i opened it and the alarm did go off so it is working but not detecting any movement my niece was playing around with it but don't know wot she don't can anyone help its a accenta g3
Posted: Wed Aug 22, 2007 7:13 pm Post Subject:
hello thanks for replying the panel or cabel can't be damage becase the alarm has been working for the past 3-4 years can you please tell me how to fix it
Joined: 28 May 2007 Posts: 183 Location: Surrey, United Kingdom Thanked: 0 times
Posted: Wed Aug 22, 2007 7:19 pm Post Subject:
Follow jim'll fix it's advice, if the system then sets that alarm sensor is faulty and requires replacement. If it still doesn't set then it's cable or zone fault.
__________________ Do it yourself, it'll be fine. Whats the worse that can BANG happen
Posted: Thu Aug 23, 2007 9:55 am Post Subject:
maybe so but that doesn't mean the cable is not damaged for example a rodent may of chewed through it ? No saying thats the case but i've seen it before. So therefore you need to cary out the following tests as already described by us.
Go to the pir remove the cover and twist the pair connected to N/C and C together this will fool the panel into seeing a close circuit.
Now take the pait in the terminals most likely marked tamper or T and T and twist those together this willo fool the panel into seeing this as a closed circuit.
Leave the wires in the terminals marked + and - or 12v / 0v depeding on how they re labelled. Now if you put a multi meter between these two terminals you should read between 12 and 14 v dc.
Try and set the system if it sets the cable is OK but the sensor may require replacement. If it doesn't work then post again with details of what happened when you tried this
Posted: Thu Aug 23, 2007 12:59 pm Post Subject:
hello can you please find me a diagram or something cuz i find it really confusin or tell me step to step by the way i pressed prog 9999 the system went to attak and then i opened the pir and then i loosened the tamper wire and i closed it back and know the system wont go out of tamper shall i tighten the tamper wires if i open the cover know will the alarm go off or not
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
