Joined: 22 Aug 2007 Posts: 4 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Aug 22, 2007 9:50 pm Post Subject:
Kitchen Rewire
Hi all.
I am just about to fit a new kitchen including a bit of rewiring.
I am obviously going to have the work inspected and signed off by a qualified person but I have a couple of questions.
1 - Do all of my kitchen appliances HAVE to have a fused Spur (Washing machine, fridgefreezer, dishwasher, tumble dryer). Is this a must?? or is is just recommended???
2 - Do sunken ceiling lights in a kitchen need to be IP rated, if so what rating or does this only apply to the bathroom???
3 - If I am chasing in 2.5mm Twin & Earth then do I still need to use conduit or such like ????
Thats about it for now but i'm sure I'll think of some more soon
Joined: 05 Jun 2005 Posts: 707 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Wed Aug 22, 2007 10:02 pm Post Subject:
the work will need to be installed to BS7671 and the Building Regulations. By following these codes of practice the system will be safe and comply with the relevant rules
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Wed Aug 22, 2007 10:13 pm Post Subject:
1i. There are 2 ways to comply with the building regs:
a)use a qualified electrician to do all the electrical work.
b)notify the local building control that you intend to do the work yourself, and pay their charge in advance. They will send someone to inspect and test.
1ii. They dont have to have a fused spur, but where a socket is located behind a permenant appliance such as those you mention, it should have accessible isolation. This can be accomplished by a 20 amp double pole switch located above the worktop, controlling the single socket behind the appliance. The DP switch goes ON the ring main, not as a spur.
2. No they dont. However it is wise to consider more efficient forms of lighting than halogen downlighters. See here.
3. There are safe zones that extend horizontally and vertically from all electrical accessories. In these zones it is acceptable to run cables without additional protection. There are also safe zones 15cm from every corner of every wall. It is always recommended, however, to use metal or plastic capping to protect from the plasterers trowel.
Posted: Wed Aug 22, 2007 11:10 pm Post Subject:
CRAFTY, I read the link to alternative lighting and have to exclude the led's mainly due to the not white light issue, if you use the CFL bulbs then are they instant light of do they behave like a flouro tube (flicker) or like an energy saving bulb (take a while to brighten up)????
They sound intersesting and having to space the gu10's away from joists is a pain when it comes to planning
Joined: 07 May 2007 Posts: 1457 Location: Lincolnshire, United Kingdom Thanked: 23 times
Posted: Thu Aug 23, 2007 5:53 am Post Subject:
They take a little time to warm up like most other CFLs. I seem to be plugging LEDs a lot just recently for some reason, but have you taken a look at warm white models instead of the typical cool white that you describe?
__________________ Matthew
"I told you, I only wrote that poem to test my printer!"
Posted: Thu Aug 23, 2007 10:51 am Post Subject:
CFL = Compact Fluorescent Lamp.
This is the technology that describes the energy saving lamps that plug into standard lamp holders (GU10, edison screw and bayonet), as well as the newer PLC 2 and 4 pin type fittings.
It seems to me that the more compact they make these lamps, the longer they take to warm up and reach full brightness. The 9 watt ones in my bathroom take a good 2-3 minutes to warm up, but this isnt a problem as they are left on all night. And while warming up they give enough light to have a no2 etc.
Posted: Thu Aug 23, 2007 6:02 pm Post Subject:
Hmmmmm. The warming up tie could be a problem for a kitchen, I can appreciate that if may give off enough light for you no.2 but when it's half time and Spurs are beating Arsenal 3-0, I just want to run to the kitchen, click on the light, grab a beer from the fridge and get back in to see the replay of the goals!!! not wait about for my lights to warm up!!!
I could always get the missus to go and switch them on at the 40 minute mark
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
