cheez
Joined: 23 Aug 2007 Posts: 1 Location: Australia Thanked: 0 times
Posted: Thu Aug 23, 2007 12:46 pm Post Subject: Single lever mixer tap stiff |
I have a single lever mixer tap in the kitchen. It no longer moves smoothly. It's stiff for both hot and cold and swivelling between the two.
I've opened the cover and unscrewed the handle, but there's nothing in there that makes sense to me. Can it be repaired? If so how. If it can't be repaired, is it easy enough to dismantle and install new one? Thanks. |
Softus
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Thu Aug 23, 2007 8:09 pm Post Subject: |
It's probably either:
1. Scaled up and needs descaling.
or
2. Damaged, i.e. something has broken and making it start to seize up.
You should be able to buy a replacement cartridge, but you'll need to know the make and model. Do you have that information? |
