Joined: 25 Aug 2007 Posts: 3 Location: Hampshire, United Kingdom Thanked: 0 times
Posted: Sat Aug 25, 2007 8:05 pm Post Subject:
fitting a new toliet
fitted a low level toilet today and it seems to be leaking underneath but cant see where and the screws that holds the cistern to the pan the right hand side seems to be leaking very slightly i keep on tightening it and it just seems to carry on leaking any help greatly recived
Joined: 21 Oct 2004 Posts: 19532 Location: United Kingdom Thanked: 6 times
Posted: Sat Aug 25, 2007 9:09 pm Post Subject:
Is this cistern that type that has screws that go right through the ceramic base, or coach bolts that hook onto a galvanised plate under the cistern?
If the former then these often come with conical washers and make a good seal with using silicone.
If in doubt then use silicone sealant to fill the gap (from underneath) around the bolt where is passes through the base, before adding the washer and nut.
Joined: 08 Feb 2004 Posts: 6462 Location: Wolverhampton, United Kingdom Thanked: 5 times
Posted: Sun Aug 26, 2007 8:42 am Post Subject:
Re: fitting a new toliet
ukstyx99 wrote:
The screw that holds the cistern to the pan the right hand side seems to be leaking very slightly
I solved this by changing the steel washer under the wing nut for a larger one. The larger area of the washer enabled the cone to be tightened up more and done the trick.
Posted: Sun Aug 26, 2007 4:41 pm Post Subject:
When bolts go through the cistern they are intended to be tightened and leak-free before lowering the cistern onto the pan. The second pair of nuts/wingnuts is there only to steady the cistern and compress it onto the doughnut washer. If you rely on the second set, then in the course of time it will leak as the doughnut loses its restitutive ability and compresses even further, thus allowing the bolts to become loose again..
So, you can mask the problem temporarily by tightening the bottom nuts, but it is no cure.
Posted: Sun Aug 26, 2007 9:08 pm Post Subject:
Bahco wrote:
In my case the leak was coming from the hole that the wing nut fits into and not from the donut washer. My cure did fix it.
That's exactly the leak that I was talking about, but did you have a c/c adaptor plate, or did the bolts go through the cistern just like the OPs seem to (although we're awaiting confirmation on that)?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
