DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Loose sink mixer tap
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
NeverPlumbedB4
from United Kingdom
PostPosted: Sat May 29, 2004 11:55 pm Reply with quote
I wonder if anyone can help. The tap in one of my bathrooms is very loose (rocking around when touched), but not leaking. I have had a look underneath and there is an inch long bolt, but this seem tight. There is however stick white residue.
Had a look at a similar tap in other bathroom and the fixtures appear to be the same.
Can anyone suggest what I could do apart from calling out a plumber.
Back to top
 Alert Moderators
AlanE
from United Kingdom
Thanked: 445 times
PostPosted: Sun May 30, 2004 8:18 am Reply with quote
Remove offending tap, clean and refit.
Alan
Back to top
 Alert Moderators
NeverPlumbedB4
from United Kingdom
PostPosted: Sun May 30, 2004 8:59 am Reply with quote
Thanks for this. However, is this a simple job considering I have never done anything like this before?
Back to top
 Alert Moderators
AlanE
from United Kingdom
Thanked: 445 times
PostPosted: Sun May 30, 2004 3:26 pm Reply with quote
Difficult to answer that really.
Any job cn be simple or difficult depending upon your skill level plus available tools.
Alan
Back to top
 Alert Moderators
NeverPlumbedB4
from United Kingdom
PostPosted: Sun May 30, 2004 6:21 pm Reply with quote
Thanks Alan
I'll get a DIY plumbing book as I have spanners and give it a go!
Back to top
 Alert Moderators
justlooking
from United Kingdom
PostPosted: Sun May 30, 2004 7:00 pm Reply with quote
You will need a tap spanner.
Back to top
 Alert Moderators
CAPMARTIN142
from United Kingdom
PostPosted: Sun Jun 13, 2004 9:40 am Reply with quote
a tap spanner will make it much easier! I can tighten taps up with it and I'm not very strong! you could also use top hat washers underneath but this would involve removing connections. check if you can isolate the water supply. there may be an isolating valve on the pipework. to stop the flow you must ensure that the notch that your screwdriver fits into is running the width of the pipe and vice versa
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
How do i stop mixer tap being loose on sink 3 880 Sun Jul 03, 2005 7:48 pm
Kitchen Sink Swivel Mixer Tap Loose 16 12700 Sun Jul 15, 2012 7:21 pm
Newby with no experience - Kitchen sink outside waste loose 18 180 Tue May 21, 2013 7:33 am
Loose sink tap 2 480 Sun Mar 02, 2008 11:23 am
Loose Mixer Tap - How to tighten? 5 1200 Mon Jul 23, 2012 5:46 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
