This shows you the differences between the selected revision and the current version of the page.
avwiki:sky:magiceye |
avwiki:sky:magiceye 2009/06/16 23:11 current |
| | + | ====== Switching on the Magic Eye ====== |
| | + | If you have plugged in a Magic Eye to the 2nd output on your sky box and the 12v supply is not switched on:\\\ |
| | + | On the sky remote control press the services button.\\ |
| | + | Select option number 4 (System Setup)\\ |
| | + | Now - using the numerical keypad press 0 1 Select (do not use the up and down arrows to select option 1)\\ |
| | + | You should now be at the Installer Setup\\ |
| | + | Select option number 4\\ |
| | + | Change the RF Outlet Power Supply to ON\\ |
| | + | Select Save New Settings\\ |
| | + | Press the Sky button to exit\\ |
| | + | Note:\\ |
| | + | A magic eye or a compatible device must be connected before any TV, VCR, DVD recorder etc as the 12v supply from the sky box could cause damage.\\ If in doubt, consult the manufacturers instructions. |
