This is occurs when there are surfaces in the house which are cooler than the warm damp air inside. You can control it by reducing the amount of moisture in the air (by ventilation and by reducing steamy activities) or by making the surfaces less cold.
It is a nuisance when the amount of moisture generated by activities in the house exceeds the ventilation flow that gets rid of it. Moisture held in the (warm, damp) air will condense out when it reaches a cooler surface. This is very obvious on the outside of a glass will an iced drink in it, but also happens on outside walls and windows.
Double-glazing makes the inner surface of glass less cold, but it also usually reduces the amount of ventilation so that there is more moisture in the air.
If you want to experiment, tape a piece of clear polythene tightly to one of the damp walls, see if you get more water forming on the wall side or the room side of the polythene.
There are other sources of moisture. Look for any signs of water getting in, especially small roofs over bay windows, or leaking radiators, downpipes or other plumbing. Sometimes it is caused by wet under the floors, perhaps due to waterlogged ground in low-lying areas or near a river, sometimes by a leaking watermain.
If you get condensation in the loft, it is probably due to warm air leaking up from the house (especially the bathroom) but it can be due to a plumbing/CH fault putting hot water into the loft tanks. Lofts should be well-ventilated to avoid the risk of rot in the timber. Sometimes loft insulation blocks the air gaps at the eaves, so it should be pulled back a few inches.
If you get condensation of the ceiling (especially noticeable in bathrooms when you get black spots where the cold nail-heads are under the surface of the plaster) then the insulation above is probably gappy, or very thin, or absent. This can easily be corrected.
JohnD 20070124
| Subject | Posted by | Replies | Posted at | |
| condensation | Guest | 7 | 07 Nov 07 at 14:28 | |
By using this site you agree to our Terms of Service / Disclaimer. Please read our Privacy Policy. Copyright © 2000-2008 DIYnot Limited. All rights reserved. Reproduction in whole or in part in any form or medium without express written permission of DIYnot Limited is prohibited. |
