DIYnot
Local | Network
Local | Network
DIYnot Network Local DIYnot Network Local
Air Admittance Valve
These are NOT normally referred to as AAV's
Big ones (which fit 100mm diameter pipe or above) are often known by the trade-name Durgo. They are designed to let air IN to waste or drain system, so that siphoning does not occur. Such siphoning can “pull” the water out of a trap so smelly air passes upwards. They do NOT let air out. Individual fittings are available from 32mm diameter up, or they can be built in to a trap, such as this one - the little part which looks tacked on the top is the Air Admittance Valve. The traps are known as Vented or Anti-Siphon traps.
Courtesy of ChrisR
plumbing/air_admittance_valve.txt · Last modified: 2008/03/28 20:43 by DIYnot
DIYnot.com
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum | Shop
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
Copyright © 2000-2009 DIYnot Limited. All rights reserved. Reproduction in whole or in part in any form or medium without express written permission of DIYnot Limited is prohibited.
