DIYnot
Local | Network
Local | Network
DIYnot Network Local DIYnot Network Local
Gas Boilers
The boiler is the device where fuel (gas, oil, etc.) is burnt and the heat transferred via a heat exchanger to water which then circulates around the heating system. The key control on any gas boiler is the boiler thermostat which operates the gas valve. Modern boilers are much more sophisticated and include a wider range of controls.
Combi boilers
Combi boilers produce hot water instantaneously. None of this water is stored. Virtually all heating systems which utilise a combi boiler are known as a sealed system. This term refers to a heating system whereby the expansion tank that the hot water expands into is sealed and not open as in a traditional open vented system.
Combi boilers generally have two heat outputs. 1 heat output is usually higher than the other. The DHW or Domestic Hot Water heat output is generally higher as more heat is required to product a larger amount of hot water per minute. For example a Vaillant EcoTec Plus produces 24 KW of heat for domestic hot water, this ensures that it can, where possible achieve a flow rate of 9.4 litres per minute. The CH or central heating output is however only 19 KW. This is simply physics as only a certain amount of heat can be injected into cold water per minute so the higher the DHW heat output the higher the amount of hot water the boiler can potentially produce.
I say potentially because combi boilers can produce an amount of hot water per minute equivalent to the amount of mains cold water coming into the boiler. So for instance if a combi boiler can produce 15 litres of hot water per minute, then the boiler requires at least 15 litres of cold mains water coming in to produce at best the same amount of hot water. If there is a demand for hot or cold water elsewhere in the house then the amount of hot water being produced by the boiler will be reduced, as this is effectively either splitting the DHW flowrate or less cold water is coming into the boiler.
It is worth remembering that combi boilers really hate hard water. If you live in a hardwater area it is always worth fitting a scale inhibitor to reduce that amount of limescale in the water before it reaches the boiler. Stainless steel heat exchangers generally last longer and are less prone to limescale. This is apparent with the Baxi Platinum which offers a 5 year parts and labour warranty.
Generally for a decent shower it is best to get a combi boiler which can produce at least 11.5 litres of DHW per minute. Remember that power showers cannot be used with combi boilers as this kind of shower uses a pump, but the boiler may not be able to produce enough hot water for this pump.
Also bare in mind that combi boilers are often installed in the wrong situations. Many plumbers/corgi engineers base their boiler choice on the DHW heat output. This is not how a survey for a suitable combi boiler should be carried out because of the details above about the two different heat outputs. Remember to always check that the CH output is suitable for your property.
System boilers
System boilers have the components of a sealed system (expansion vessel, PRV, pump) built into them to simplify the installation. It follows that they are always used on sealed systems and do not require feed and expansion tanks.
Condensing boilers
Condensing or High Efficiency (HE) boilers are more efficient than Standard Efficiency (SE) boilers because they incorporate a second heat exchanger through which the flue gasses (products of combustion pass, this extracts more heat from the gasses before exhausing them to atmosphere. The second passing of the flue gasses results in them being cooler than standard efficiency boiler flue gasses so they condense in the flue & cause “pluming” (steam) to be seen coming from the flue terminal. The condense in the flue drains back through the boiler & passes to waste, the condense is slightly corrosive & should not drain through steel or copper pipework.
Related forum topics
Subject Posted by Replies Posted at
Forum Topicbanging pipestamra4 04 Nov 07 at 3:08
Forum TopicWhich Boilertonyd14 08 Sep 07 at 14:34
Forum Topicvaillant combilindam151021 06 Sep 07 at 14:47
Forum TopicDHWPORTNAHAVEN13 25 Jun 07 at 18:18
Forum TopicAnti Cycling Deviceccip1 15 May 07 at 10:46
Forum TopicBanging boilervztfzc4 09 May 07 at 22:32
Forum Topicboiler problemFoofs8 08 May 07 at 13:49
Forum Topicvalliant combiminhydra5 06 Apr 07 at 10:20
Forum Topicboiler cupboardcillian1 30 Mar 07 at 19:08
Add a comment or question about
this article in the forum:
Your comment or question:
First,
Existing users click here to log in.
New users click here to join FREE!
Then,
 Subject:
 Comment:
plumbing/gas_boilers.txt · Last modified: 2007/09/12 09:18 (external edit)
DIYnot.com
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum | Shop
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
Copyright © 2000-2009 DIYnot Limited. All rights reserved. Reproduction in whole or in part in any form or medium without express written permission of DIYnot Limited is prohibited.
