Need help finding replacement seal for my belling cooker
AL
23 Sep 2003
Hi There,
Moved into a new house and the ovens door seal has broken. Problem is I cannot identify the model number of the cooker so can't really order the part I need :( I tried a universal seal it was naff and lasted 5 minutes and i took a punt on one that looked right but wasn't and ended up wasting £20. Any help appreciated.
The oven is an integrated belling synergie. It's a single oven with grill function. The old seal is a square-ish bit of rubber with a hook in each corner. The size of the oven opening is approx 35cm x 44cm
Cheers AL
Thanks, I sent them an e mail. I'll see what happens?
Finally got a reply from their customer services, very helpful - not. See below:
Thank you for your email to Customer Support.
Spare parts are normally available directly from us.
Sadly we are not able to proceed with your query as we cannot locate a part without a 9 digit model number, and serial number.
Therefore please call us on 0871 222 2506 with the 9 digit model number and serial number of your appliance (we can assist you in finding these if need be) and we will proceed with your query.
So, back to square one :(
It could well be the right part, but I've already tried buying one I thought may fit and it didn't wasting £20. I could try this one but then I'd be down another £30 if it's not the right part.
If anyone here has a belling cooker that is of the dimensions previously mentioned (35cm x 44cm) can you let me know what model number it is or if you have one of the models below can you let me know what the oven dimensions are. Thanks in advance.
Belling
640 ST, 863 SS, 864 BL, 864 ST, 864 WH, 865 SS, 866 ST, 867 SS, DB60SS ST, G706 BL, G706 WH, G708 BL, G708 WH, G709 SS, G709 WH, XOU176 ST, XOU250 BL, XOU250 WH, XOU251 BL, XOU251 GR, XOU251 SI, XOU251 WH, XOU252 BL, XOU252 GR, XOU252 SI, XOU252 ST, XOU252 WH, XOU270 BL, XOU270 BU, XOU270 GR, XOU270 SI, XOU270 ST, XOU270 WH, XOU271 AL
