Wires not covered and plasterer comes tomorrow...
19 Dec 2008
Bradford
Hi all,
Hoping someone can put my mind at rest.
The sub contracted electrician from the building company currently doing an integral garage conversion for me did his work today.
Am turning half the garage into an internal room (play room)
Fully separated from the rest of the garage (blocks and bricks etc).
He extended the ring to re-place original sockets and removed the old garage light and wired up new circuits (2) for several downlighter spotlights.
My question:-
All the cabling (twin earth pvc std stuff) is just cable clipped in place and tomorrow I will be having plaster boards dotted and dabbed over the top of it.
Just want to check whether the cable is supposed to be inside trunking/covering to keep separation or is it ok for the plaster/adhesive to come in contact with the cabling?
many thanks
I thought this changed with the 17th.
522.8.2
Conduit or capping to be used.
I've always used ovals
522.8.2 only applies to a conduit/ducting system. It basically means that you must construct the conduit/ducting system before pulling in any cables. It has nothing to do with non-conduit/ducting installations, such as t&e buried directly in plaster/behind plasterboard.
And that isn't a new regulation, it was in the 16th too ;)
