Water pipes making noise
S
skuba
whenever we switch our taps off, or after the toilet has refilled with water, we get a loud banging/knocking sound for a few seconds
does anyone have any ideas as to what may be causing this?
thanks
sorry about this, i've just seen a similar thread 'Noisy water system' so i'll have a read through that as well
EDIT: actually, it's not exactly the same problem as the other thread. we don't have any water tanks and it's a combi boiler
It's probably just the pressure of your water.
Do you have high water pressure?
Does it happen on all your taps?
Has it always happened since you've had the combi?
If the taps have recently been installed, are the pipes securley clipped?
thanks for your reply
to be honest, i don't know how to check whether or not our water pressure is high
no, it only happens on our taps upstairs
no, it's only started to happen within the last month or so and the combi boiler's been installed for over 10 years
it sounds like the noise is coming from the water pipe leading to the toilet in the bathroom
So does it not happen on the hot taps?
sods law - it's not happening at the moment so i can't test it for sure, but i'm sure happens on both hot and cold taps. also, the noise sometimes happens without running any taps or flushing the toilet
