Hello -- I'm planning to build 4" stud wall between bedroom and bathrooms and 3" between that and outside wall between 2 bathrooms. The 3" in a kind of square "S" shape to create shower cubicles for each bathroom. The bedroom side will be skimmed and either painted or papered. The bathrooms side will be tiled.
I was thinking of using 12mm WPB Ply on the bathrooms side of the 4" and on both sides of the 3" between bathrooms. I think this will be stronger, less likely to degrade, and also have a heavy wall mounted bath filler which ply will support better than plasterboard (spigot through wall then back nut holds it in place).
Cost of boards is similar, ply slightly more but cost difference no issue. Can anybody see any disadvantages to doing this? If I fill void with insulation, would that meet building regs?
Thanks for any advice, Peter
