Screw supplier
2 Jan 2009
Lanarkshire
Hi
I'm looking for somewhere I can buy various size metric machine screws in a black finish. I've googled a bit but can't find anywhere.
Any ideas?
Colin C
Have you tried B&Q or screwfix?
Failing that do you have a local motor factors, or engineering supply shop.
Standard unplated steel bolts and screws look black(ish). Fastfix are a good online supplier.
If the finish is important you could get the materials to blacken them chemically. However, when I've need to do the same in the past I've decided that painting the heads black is the easier option.
