D
Deleted member 105431
personally I would say all Salus products are crap. Honeywell have the market sewn up and the quality speaks for itself. I am always getting called out to faulty salus units, they are $hit!
BEWARE: anyone fitting salus rt stats, DO not use any force when tightening the wiring terminals. check the tightness on the factory fitted link ,that will show you that they know the soldering is very poor!!!!!!!!!
leeds plumber
could you please mail me the plain english version of the instructions for the salus rt500rf.
Also is there an option to say the scenario was you`ve arrived home, it`s cold and you want the heating on immediately. Can you push a button and on it comes?
can you send me the easy instructions cheersThe reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
I have had quite a few customers who struggle with the instructions so i typed it out in plain English as a word document and give it to them so its easier, if you want send me your e-mail address and i will mail it to you.
