I am a bit bitter and twisted, 'cause I have just spent 5K on plumber - looks fab, but we now have an external shower from the dripping flow and expansion tank (great for ducks, annoying to humans). The water is backing up the feed and the plumber has hot-footed it out of town (typical!). System spec is: HRM wallstar 15-20 oil-fired boiler with Centrecal 120 high performace indirect cylinder with de-aerator and bypass valve fitted. Sentinel X100 inhibitor was added. Central heating flow temp is 84 deg C, return temp is 78 deg C.
Correct me if I am wrong, but I think I may have eliminated the usual suspects: when the ballcock in the cold water storage tank is tied up and then drained, there is no changing level in the feed and expansion tank, which suggests that there is no problem with the coil in the cylinder (?) There is no change in the level of the F&E tank on heating/cooling and no airlocks in rads, both of which suggest lack of expansion (?). I have twisted the Pegler diff bypass valve in the hope that is cures the problem, but confess that I did not understand what the hell I was doing, and all it seem to do is relieve the pressure of my frustration for half an hour . Diff. pressure valve is the same model as screwfix sell (one with blue valve top)
Strange things happen: today when the Central heating and HW have been off for 5 hours, there was a sudden rush of water out of the F&E tank and then it stopped....eh? Does this suggest that there is an airlock and I have not found it, or sudden change in water pressure? And why is the dripping most prevalent 5 mins into the CH being turned on, lasting 40mins and then dripping is noticeably slower?
Can the diff pressure bypass doing anything to help (what should be the correct setting anyway??) and, would turning thermostat up/down on boiler help?
