I've got the fitting templates for my two boilers — a Vaillant 618 system boiler and a Rinnai 26i water heater. I'm trying to work out the exact positions on the loft gable wall to mount the boilers, and I could do with some advice.
The diagonal webs of the (not very tall) roof trusses are turning out to be a real pain. Ideally I'd modify them, but to do that legally I'd have to involve a structural engineer and Building Control approval, and that's just too complicated.
The drawing below shows the best compromise I've been able to find.
The pink area shows the area that the building regs say the flue terminals can't encroach upon due to the minimum 200mm proximity with the eaves on the outside.
The boilers can't really go anywhere other than the central triangular area. The areas further out (the other sides of the diagonal webs) are too short once you take out the pink bit. I've also read somewhere that two boilers shouldn't be less than 100mm apart.
The only trouble is, this position puts the flues only about 80mm from the diagonal wooden trusses. Is that OK? I can't find any firm data about it on the web. Admittedly it's more than the minimum 75mm they're allowed to be away from things like guttering and drain pipes.
Any advice offered will be gratefully appreciated. Cheers.
