Hi all,
We have full glass danger doors in the hall, two standard with the middle. cut out and replaced with glass.
A third I made as a folding door using two redundant ones from the kitchen- with two narrower same glass panels, hung at the top only.
The front hall door is also a full glass etched panel with matching side panels. But we do have a porch enclosing all.
These must all be replaced of course.
My question is what ideas or prompts do you have.
I thought of toughened glass with small panels, but painting is difficult,
hardwood means the jambs and skirting also to replace.
and then the folded door is odd as it's painted now.
Then the front door, if double glazed is odd (and white)
In short- a problem ennit.
Thanks in advance for any ideas
