Programmer Wiring
10 Sep 2010
Bristol
Hi All,
Can anyone help with what wires I should connect to a new Horstmann Channel plus H27XL.
I have a gravity HW and Pumped CH system with room stat (no cylinder stat)
Here is the existing timer Horstmann Diamond
View media item 26102
Here is the existing wiring
View media item 26103
View media item 26115
what wires control what and have had a go at replacing
View media item 26135
I have the installation instructions here but cannot work out what goes where exept for the L,N and E and I can see that I need to link L 2 & 5 which I have done. I have also removed the gravity link.
I have DHW going to 1
Room stat (yellow) going to 4
CH pump (Red) going to 5
CH Pump (Yellow) ? this is where I have a problem can not work out where to put this wire.
View media item 26136
http://www.horstmann.co.uk/downloads/ElectronicDocuments/Central-Heating/H21-27-27ZXL-ISeries2.pdf
Any help will be most appreciated
Try removing the link that you fitted between 2 and 5, and then put the red pump wire into 5 and the two yellows into 4.
Many thanks, tried this and Boiler fires up when I select heating on but the pump does not run, turnt uo the room stat and still no pump running. :(
Ok, replace the link between 2 and 5, the red goes to 4, and the two yellows go into a piece of choc block they do not connect to the programmer.
:LOL: YES that's done it thanks holmslaw, your a star :LOL: all working and pump switches off when Room stat turned down.
Thank you
