Should I drain the CH or leave it alone?
17 Sep 2008
I have an empty house, and the weathers becoming frosty. I've turned the water off at the stopcock under the sink and opened all the taps. I'm wondering if I should try draining the radiators or not.
About a year ago the old boiler was replaced by a condensing boiler. The immersion tank was removed. The old radiators were not replaced.
Should I drain the radiators, or would it be better to leave it alone? Is it likely to be a sealed system now?
Thanks.
Sorry, maybe I should have gone into more detail.
1) Is it likely to be a sealed system? Any way of telling? Would the particular boiler model be ebough to tell me?
If it is a sealed system:
2) will it drain down when I open the radiator drainage valve?
3) will it just fill up again when I turn the water on, or does a plumber need to do it? In which case it may be cheaper to leave the CH on a low setting.
If it is not a sealed system then I assume the answers to 3) and 4) above would be "yes".
Does the boiler / system have a pressure guage on it somewhere?
If it is, its a sealed system:
Not propery, you will have to open up all the air release points on the system - creating an open vent type system.
If its a sealed system, you or your plumber will have to manually re-fill / vent it - all of about 10 mins work. You will have to re-treat with inhibitor though. Leaving the heating on 'low' 24 hours a day may work out cheaper.
Point 3 - yes.
Regards,
Mister. W.
