Hi Guys if anyone could help me you would save me getting a new boiler…
Ok well this is a intermittent problem with the boiler some times it runs ok and sometimes it doesn’t
When it is not working the problem is that the hot water runs as normal getting to a hot temperature but all of a sudden the flame cuts out and then fires straight up again within seconds; however this will produce around 20 seconds of cold water through the outlet (bath tap, shower or kitchen tap etc) before it then starts to warm up again! At first this seemed to happen when it reached to the 70 degrees mark but now happening more and more at different temps.
I have noticed this also happening to the central heating to but this does not effect it as the rads still get well hot!
Has anyone had this problem or has anyone ever fixed this problem
A friend (who is a heating engineer for 4 years) has tried a number of things for me free of charge like… heat sensors, cleaned heat ex, checked condense trap, replaced pump all to no avail
Please help I don’t want this to cost me thousands or even hundreds and then still not have it fixed and have to buy a new boiler after all!?!?!?
I have upload my problem to you tube search for “Baxi105HE problem”
