Workin Pressure at appliance too low??
22 Nov 2010
Glasgow
Just looking for a wee bit of direction on where to go with this.
Installed a new 4 kw gas fire. Gas supply comes into property in 22mm drops to 15mm for around 2m then the last 1100mm is in 8mm with 3 formed bends around the chimney breast and into fire.
Min working pressure at appiance is 17.05mb, however I am acheiving 16.5mb.
Suggestions have been to take form bends out of equation by fitting a pedestal and 8mm rod straight to fire, however customer wasnt keen on the ped protruding out the floor.
Any advice would be greatly appreciated thanks.
What do you have at the meter test point when the fire is running?
You should be in the Combustion Chamber for registered gas installers.No DIY gas advice on the public forum.All you need to do is join IF you have a valid gassafe number.Simond you should know better. :!:
