2 way lighting with Flouresent lights
10 Aug 2005
Hi
I will be wiring a 2 way switch with florescent lighting, on your two way switch diagram does the circuit cable go to the lights or the mains..
If it goes to the mains is the lighting cable missed out and vice versa..
To make things simple. I intend to run 1 wire 1.5mm t&e from switch to all florescent fittings terminating on the last one. Then join up the two way fitting, will this work.
finsuk said:
Hi
I will be wiring a 2 way switch with florescent lighting, on your two way switch diagram does the circuit cable go to the lights or the mains.. .
The mains via the ceiling rose
If it goes to the mains is the lighting cable missed out and vice versa.. .
see above
No it will not work (see the for reference section for details)
Ca you tell me how or do you have a diagram to connect up 6 Flouresent lights on a 2 way light circuit From live feed t&e.
thanks finsuk
The first fitting as per the reference and the rest Red to L on fitting, Black to N on fitting and Green/Yellow to earth terminal
