4" x 10 screws for securing decking joists
21 Sep 2005
Which type of screw and size should i go for to join the joists?-i don't want to nail .after doing some relentless searching i found one or two use the above screw but can't find a stockist.i'm wondering which type you guys use and where to buy in bulk?
many thanks.
i'm talking about making the frame.
as for joining to the posts-coach bolts. :?:
http://www.screwfix.com/prods/78121/Bolts/Turbo-Coach-Screws/Turbo-Coach-Screws-Zinc-and-Yellow-Passivated-M8-x-100mm-Pack-of-50?cm_mmc=GoogleBase-_-Datafeed-_-Bolts-_-Turbo%20Coach%20Screws%20Zinc%20and%20Yellow%20Passivated%20M8%20x%20100mm%20Pack%20of%2050
maybe these????????????
Yes those are perfect, and brilliant when used with an impact driver. No drilling, no cam-out or broken pozi bits
Or just get the coach screws
4" x12=100mm x 6mm..right???
your first link sounds the cheapest.pfft..carling black label alters the train of thought!! :p
i get some of my fixing from a site called leofixings ,never had a problem with them,decent price too
