Hi, I'm looking for some guidence from anyone who is familiar with Anhydrite/Alpha Hemihydrate floor screeds. I've removed a small 'L' shaped section of wall (750mm x 600mm)from an area that has been screeded using CEMEX SuperFlo which I'm told is a Alpha Hemihydrate. As a result I'm left with a trench 150mm wide and the depth of about 100mm. To either side the screed approx 50mm plus 50mm insulation. Under the insulation is a beam & block floor. The question is how do I make good the which will eventually be finished with natural limestone (20/22mm). I'd thought of filling with a sand/cement (3:1 mix). Would this be OK? Would I need to use a special primer? Will a cement based mix react adversely with the flow screed? The existing screed was put down 5 years ago.
Cheers, Jim
Cheers, Jim
