it is a standard efficancy boiler that can do heat or h/water depending on how it is piped up if it does h/water you will find a copper cylinder,it is not a combi
Thanks for reply,boiler definately runs ch, so no chance it heats dhw as well.Probably explains conflicting views on web (did try to find out first)She says there is tank in cupboard with the name Elson Coral B.Maybe this is heater-Im going over tonight with me torch...
Thanks to everyone for your input,Turned out fuse blown in spur on the Elson.So far so good,expect it will go again,fuses dont usually blow for no reason, just wait and see!
