Hello. I have a nest of tables. The legs are discretly attached to the table top with a bolt. The problem is the wood has been damaged slightly and so the bolt is not held in place properly.
To cut a long story short: I need to patch up thewood with a filler and re-drill a hole which will be able to support the bolt.
Can any body recommend a suitable filler which can be drilled and screwed?
I have seen that some wood fillers are expensive, but I only need a little bit and might not use it again.
Thanks,
Hajj
Thanks,
Hajj
