I'm planning a 6m x 3m shed on a concrete slab, then stud walls with featherboard. In order to attach the footplates to the slab, is it best to let the concrete set then drill holes to screw/bolt the plates down, or should I bed upward pointing bolts in the wet concrete so that I can attach the footplates to after it's set? Drawback with the latter is aligning the holes in the footplates to the bolts but I am hoping that won't be too difficult.
Or is there another (better?) way of doing this?
Chris
Chris
