Hi guys my preparation for my Parquet is moving on at a steady pace and so here is my next query.My plan is to lay Herringbone pattern across the room and finish off the full perimeter with a 3 block width border.Is it general practice to hire a plunge saw and run round the full room perimeter (3 block width from the wall) in my case or mitre the triangular pieces that slot between the ends of each run???. What are the pros and cons of each method and what do you or have you done in the past?. Any advice much appreciated.Cheers
