Hi All
I'm about to convert my integral garage to a living space and would like some advice on insulation. The garage has 2 external walls, the longest wall (5m) is block and brick without insulation in the cavity. The shortest external wall (2.5m) will consist of the new infill wall of block/brick and insulation and a window. The floor is a concrete slab which I presume does not have any insulation below. There is a difference in height between the garage floor and the house floor of 80mm the front and 70mm at the back. Ideally I would like the floor in the house and the new room to be the same. A builder has quoted but is planning on using 25mm insulation in the floor with a screed on top, will this be enough to satisfy the BCO? I have heard of people laying rigid insulation onto the slab and laying chip board straight ontop. If this is a good idea will I need to self level the floor or will the 10mm difference not notice over 5m. Regarding the walls, will only the external wall need insulating? I was thinking of having them fit an insulated plasterboard. The ceiling is below a bedroom so I am pretty sure this will already be upto spec. Any advice on the whole subject of the conversion would be appreciated.
Andy
Andy
