Changing a bell box
26 Oct 2010
Cheshire
Hi
I'm Changing a old faulty bell box for a new one (odesey) the terminals do not match up. can anyone confirm the wiring please?
old unbranded box:-
HOLD +
HOLD -
TRG
TAMP R
TAMP N (NOT USED)
STR
new box;-
+VE
-VE BELL
-VE TAMPER
0V
-VE STROBE
some are obvious others are not..
HOLD + = +VE
HOLD - = OV
TRG = -VE BELL
TAMP R = -VE TAMPER
TAMP N (NOT USED)
STR = -VE STROBE
OK
Hi, I'm sure that's what I did! the keypad display went to a "-"
so I powered it down to seek help!
ill double check & get back to you! (its at a late friend's widows home)
many thanks
Bell boc seems ok
can anyone help with the programming? keypad shows IFLt
is there somewhere I can download installer instructions?
thanks
Check the boc that seems okay, it needs to be okay, not "seems".
Also check the fuse (s) you have probably blown.
Box, I meant box!
the alarm wont set, and I think I need to clear the fault codes - can you tell me where I can find installer instructions?
The maker of the Karisma was ADE (optima fame)!!!
The Karizma was a Point ID format panel I have never used one or worked on one but did the old Bell-box have an ADE I.D. "buscuit" fitted in it?? ;)
