washing machine stopped working, checked carbon brushes and they were worn nearly to the limit, pushed them in and out several times put them back in two weeks later machine stopped working eg washing and spinning, replaced carbon brushes and machine started to wash a little,eg start at 56 mins stop at 47 mins, select spin only pump water out, spin programme 10mins stops at 9 mins, will not go into spin although the water is out, check filter in pump all ok, disconnect pressure swith hoses and blow down them all clear, I thought may be the new brushes needed to be bedded in so took out clothes and again selected spin but again no spin, can any one help help????
