Shutting off the gas valve
16 May 2012
London
When you shut off the gas valve it stops the gas right there,at that point.Yes there is still gas in the down pipe,but it`s not under pressure and as long as an appliance isn`t turned on or the gas carcass isn`t opened it will be fine(just like turning off your water mains).
The article you linked to is more to do with if you have turned off the gas because of a problem(smell of gas etc).If you do that then you would have to get someone qualified to turn it back on and test the installation.
If you`re turning it off to go on holiday you can quite safely turn it on again yourself when you get home.
