Over the past two weeks my central heating has developed an intermittent fault. For no apparent reason the heating cycle stops even though all the requirements to provide heat are satisfied i.e. power from room thermostat OK, timer in it’s timed ON cycle and all terminals from the timer live/non-live as they should be. But if I turn the main power switch off then on again the boiler starts up again as normal.
Has anyone any suggestions as to what the problem might be please.
