I think on the roto profile you can only adjust the doors to go left and right by 3mm. To lift the door up you'll have deglaze the door and repack it ( toe and heeling ).
cheers,also the door is not sealing to the gasket seems alright in middle but not at top and bottom adjustments on roller cams are fully taken up is there anything else that can be done, keeps also moved as far back as they will go
