Hi all
Please can someone advise me on this? My partner has a GE consumer unit and he wants a new circuit to add some sockets and lights into his garage.
The only problem is that the room that the CU is in has been insulated after the event and the CU is 'embedded' in the wall so that the front plate is the only thing that sticks out from the wall. We can't get access to the back of the CU as it is fixed to the outer wall and surrounded by the insulated wall.
All the other wires come in the back through a single hole.
My question is, is there a straightforward and safe way to put in this new circuit wire through the side of the CU (drill a hole or cut out a section in the side of the CU) if you ensure that it is sealed and meets the IP rating afterwards?
It would seem logical to me but I don't know if that is completely off track and / or illegal / unsafe
Please help!
many thanks
Bbee1
Please help!
many thanks
Bbee1
