Recommended alarm type / brand?
Well before the arguing started this was a sensible post but just takes narrow minded people to spoil the help...
Every engineer will give you different arguments for different alarms... The bottom line is there is that many out there no one will give you a straight answer.
I would say wired Honeywell and choose your accessories wisely.
Or if you we're to go wireless wisdom or visonic....
but Bernard would probably say different and mdf would as well.
Check the limitations of each system and the pros and cons. To make a informed choice.
Regards
