What equivelant burner
31 Oct 2008
Lancashire
I want to replace our crap Sterling burner with a Riellor.
Is there a direct riellor replacement to replace a Sterling elecro oil 50 if so what riellor model ?.
Yes there will be one to fit is the short answer, BUT the Riello will cost more when you need to replace parts. Although I assume you have had problems with the Sterling, they are normally a very good burner and very reliable as well (Danfoss coil excluded). Is there any particular reason you want to change?
Yes, it keeps locking out.
I have had a long establishes heating co see to it & they replaced the control box & jet, they serviced it etc etc.
It's always the same, it will work properly for a couple of months then lock out again. They always put it down to "the settings".
When it locks out, which is only ever on 1st of day fire up, I can getting going by,
press loch out trip button,
as the motors run but before it's supposed to ignite, I have to turn the thermostat dial on the boiler from low to high repeatedly say 6 or so times, it will then ignite.
Try a motor capacitor first, much cheaper than a new burner. A new burner will need to be commissioned by someone with the correct equipment, and I'm not sure whether a Riello blast tube will fit through the hole in the boiler body. Some worcester boilers will not accept the Riello flared blast tube.
