Can you recognise this Vaillant boiler?
Look on the bottom surface of the boiler and there is probably a label with the model number!
Nothing there Agile. I have good access to the underside and no labels. I can see a part 20cm up inside from the bottom which says Sigma 845, but Googling that looks like model number of a gas valve, not the boiler.
As Agile says where the pipes come under the boiler there is normally a label on the frame with GC number & model details . You might need a torch to look closely.
Thanks guys. I found it. It wasnt there. You can take the front control panel off. It hinges down. It was behind there.
Thanks!
