elson coral e
20 May 2006
Essex
Been called to this unit today.No hot water was the fault.After speaking to Elson they suggested to change the blending valve,but no difference.The sysyem is fully pressurised with abaxi solo 3 providing heat.Flow from boiler is hot and return hot.Both pumps have been recently changed.Could anyone give any help or advice on this thermal store thanks pete
it gets off of temp but as soon as you run hot tap it runs warm for 10 seconds then goes cold thanks pete
Hi Pete the plumber
did you manage to resolve your problem with the Elson Coral E and if so how ? I have similar issues with mine.
regards
dukes
