So I've recently created an ensuite in a bedroom. Connected up to soil pipe, connected up to water using a JG connector and all was well.
I then removed the toilet and set about plasterboarding the walls up and run ing the pipe work within the wall coming out near the top of the soil pipe.
Only I didn't measure it precise, now I've had the room plastered and cut the soil pipe to the right size I've realised that it's totally In the wrong place and too high up kind of In the way of the cistern.
I can't change the pipe as its ran through timber frames etc.. Is there some kind of flexible connector for 15mm plastic pipe that I can run down to my toilet from what I have. Really annoyed with myself as it will bel on show now too rather than hidden nicely under. I could maybe run 10mm pipe along as I'm having tiles laid on the floor I could place this hidden along the tile / skirting run maybe but I'm not sure if 10mm is suitable and it's a shame to not use what is already there.
Cheers[/b]
Cheers[/b]
