Optima XM6
2 Mar 2012
trying to reset to factory settings as have lost the code
tried manual way of powering completely down then linking terminals 13 and 23 then powering up etc ...
buttons dont work until i disconnect the link then it is still stuck on whatever the old code was .. supposed to revert back to factory 0123
anyone have any ideas of a work round or perhaps i am not reconnecting afterwards correctly ...
havent got a battery so power up from mains ..not from a battery source initially ..could this be the problem ???
thanks for any help
ensure all zones are linked out
make sure tamper circuit is closed, including the spring one on the pcb
also make sure that T and A are linked out, (always better with a
wire link)
link PA to SET and reset to factory
Oasis
