I have an interior wall which on the other side is the back passage/entrance for the house.
http://www.flickr.com/photos/98549025@N05/10189600876/in/set-72157636393178975
http://www.flickr.com/photos/98549025@N05/10189601966/in/set-72157636393178975
The paint on the wall was flaking and bubbling quite badly (see pic) which I assume was caused by damp? Is this the most logical reason?
http://www.flickr.com/photos/98549025@N05/10189614236/in/set-72157636393178975
http://www.flickr.com/photos/98549025@N05/10189471944/in/set-72157636393178975/
I have since sanded down the flaking/bubbling, and filled the minor holes with just normal filler rather than plaster, since doing this the filler in places also bubble up in a similar way to the previous painted surface (n.b I was going to paint over the section with damp seal but wanted to get to the root of the issue first)
http://www.flickr.com/photos/98549025@N05/10189609056/in/set-72157636393178975/
Now with regards to the cause of this...on the exterior wall side there are a couple of things, firstly my Virgin Media cable box is drilled into this wall as well as hole to feed the TV wire:
http://www.flickr.com/photos/98549025@N05/10189655843/
And secondly i noticed that there two sections of the brickwork that were the cement is missing:
http://www.flickr.com/photos/98549025@N05/10189566635/in/photostream/
Is this possibly the main cause? I guess I should fill these two holes in as a matter of course?
