Siemens Dishwasher
13 Feb 2006
My Siemens dishwasher SE24266 is no longer taking in water. It powers on but that's about it. Will appreciaet any suggestions.
Do you hear a buzzing noise when it should be taking in water?
If so the anti flood has been activated. Numerous causes for this, blockages in the system pipework is the most common. Can also be faulty inlet valve, broken wiring, faulty timer etc.
Realistically you're probably going to need an engineer in to fully diagnose the problem.
Unplug your appliance before working on it.
Yes there's a buzzing noise when the machine is switched on. Will have to get an engineer to take a look as suggested.
