I have a Smeg 220-240v Pyrolytic single oven with a connected load of 3k. The installation instructions state that if a fixed connection is used fit the powerline with an omnipolar circuit-breaker. If a plug and socket connection are used avoid the use of adapters and shunts as this may cause overheating. Previous to this I ran a 3k single oven off this socket for over 15 years with no problems so thought I was OK.
There are two double sockets in the cupboard under the units one serves the oven, the other microwave and fridge freezer the cable is connected to a 400v B20 in the RCD unit.
The oven worked fine for over 2 years when the kitchen ring tripped, the plug was hot, rewired with new plug and the oven is working fine and the plug remains cold but I no longer use the Pyro function or the turbo.
There are no spare connectors on the consumer unit and it could be awkward getting cable to the cooker. The electric hob is on the opposite wall, Is hardwiring the oven my only solution apart from, manually cleaning the oven!! which I did yesterday and although it took a long time and the oven cleaner was probably more expensive than the electric it was a better job.
Any input welcome, thanks all
