got a "Mouse in da House"
14 Apr 2007
Have you learned chaps got any good advice for banishing mice from the house?.......obviousley traps are a good starting point. would mice climb the insides of a cavity wall, we have found evidence upstairs and down, so apart from the stairs themselves could they be climbing in the cavity.
Get a cat they will solve your problem.
Find out where they are coming in and block any holes, are you finding mouse droppings? if so where?
Andy
yes they will climb up a cavity wal (well rats do anyway)
in most modern houses the stud walls will have horizontal sections in the walls
older houses (lath and plaster) generally don't, how old is the house?
We have three cats and the only mouse problem we have is when one of them brings a scalp back from a successful raid and deposits it on the door step!!
not found any droppings, as of yet, just a few nibbled things, Im afraid I dont like cats one bit, so a cat is out of the question........first thing tomorrow its off to buy some mouse traps.....
Buy the decent wire killers with a strong snap on them. The plastic ones are ****e and don't kill the moose sometimes.......one poor fella chewed his own leg off to escape. :eek:
I find this works:
The simplest way to eliminate mice in your house is to first nullify all the gravity, then pump in a trillion cubic meters of liquid hydrogen. Next perform a Satanic Mass backwards in under three seconds. Repeat one million times. Then you get the canola gland of a forest boar, eagle tails, and a barrel of fish legs and bake them into a series of attractive cathedrals. I think the rest of the procedure is fairly obvious.
Or just nuke your house from orbit, just to be on the safe side.
