Non Return valves on feeds to PEV?
17 Jan 2008
I have a bath shower mixer tap which has been installed for some time and is fed from Mains cold and Gravity hot. As this is unbalnced it meant it was difficult to get an even temperature when using the shower as any minor adjust meant the temperature would go from warm to either scolding or freezing. As the bathroom was getting a bit of a tidy up I decided to try and get the shower working better. After looking into many options I opted to install a Pressure Equalising Valve. Fitting the PEV has fixed the shower temperature issues we were having but I have quickly relised that at the PEV the mains cold is being backfed into the hot supply and leaving us with no hot water.
My understanding is to get round this I need to put a Non Return Valve (Check Valve) on the Hot supply feeding the PEV to stop the cold being backfed to the HW Cylinder. Is this correct and would I also need to put a Non Return Valve onto the Cold supply feeding the PEV too?
If you're getting 'cross-contamination' I'd say the PEV is faulty.
It would probably have been easier and cheaper to fit a Pressure Reducing Valve on the cold supply.
As said above, a pressure reducing on the cold mains seems more appropriate. Consider testing both hot and cold pressure at full bore if possible. Add a non return valve, sure, but if it's on the hot outlet, and you've already got a problems with system balancing - it'll only hinder the pressure and flow.
Secondly that cross contamination your facing is not a good thing at all, both for your pipes and safety wise. It is symptomatic of someone attempting to address an issue he should instead have solicited with the correct person.
2 Options
If you have a CWSC get a plumber to implement a demand for the shower from it. If you don't then good luck to ya.
Adding a Pressure Reducing Valve was somthing I looked into originally but couldn't find a suitable one.
There is a PRV on the mains cold water as it enters the house and registers 2.5bar. The gravity fed HW has a 2-3m drop so expecting approx 0.3bar on the HW.
Non of the PRVs I saw had a range less than 1 bar so the minimum I could set the cold water too would have been 1 bar which would still be to high in terms of balancing.
Putting a check valve on the hot would sort the issue, putting one of the cold might satisfy the regs, but in real terms not be necessary.
The problem shouldn't exist in the first place though and as mentioned, the PEV may be faulty as it is sending water back into the tank.
I am not very familiar with those valves as I don't see them as a very useful solution.
However are you sure its been correctly connected?
I would have expected most reducing valves to give an output below 1.0 Bar.
Many work best when not reducing too much. Often two in series are better.
Get rid of the PEV and check valves they are never going to work properly, have you looked at venturi showers ?
Nah, they do work fine, been ages since i installed one, as most people just choose to have an electric shower, which on these older properties normally means having a better flow thus better shower.
